tawa 150 Report post Posted August 31, 2021 Hi All, Recently purchased an E70 (2010 Xdrive35) and wish to fit a tow bar for the odd trailer trip. I'm aware not all are created equal, especially in the integration with electrickery bits, disabling PDCs, adjusting reversing camera and whatnot. Does anyone have recommendations for a good solution? I can do the appropriate coding so it knows what's what... Quote Share this post Link to post Share on other sites
balancerider 824 Report post Posted August 31, 2021 Unless you're planning on removing at times I'd probably not spend the extra on the BMW OEM / Westfalia bar (main advantage is that it's removable), but the original BMW wiring harness will play nicely with the vehicle CANBUS system, no guarantee that a generic one will. SD European appear to be dismantling several X5's with towbars and could probably do the install for you. https://www.sdeuropean.co.nz/cars-for-dismantling?make=bmw&series=csv5ba865a99525e&chassis=csv5ba865a9951be 1 Quote Share this post Link to post Share on other sites
