boyish 43 Report post Posted September 24, 2021 Anyone know the reason as to why my side mirror doesn’t perform the auto tilt? My mirror adjustment functions work perfectly on both sides (up, down, left & right) Also the mirror folding doesn’t seem to be working. Another thing is the steering wheel adjuster doesn’t work but I’ve read from several sources that it’s to do with the memory seat control module? My electronic seat functions work perfectly (heating & lumbar included) however memory function seems to have failed…? Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted September 24, 2021 The mirror selector switch has to be set to the right side mirror (I think) or it won't tilt. It also could be broken, a scan would tell you if it's broken or not. 1 Quote Share this post Link to post Share on other sites
boyish 43 Report post Posted October 2, 2021 On 9/24/2021 at 7:28 PM, adro said: The mirror selector switch has to be set to the right side mirror (I think) or it won't tilt. It also could be broken, a scan would tell you if it's broken or not. Yeah it’s set to the right side mirror. Occasionally it works correctly. Other times it goes through a twitchy tilt & corrects itself when back in drive & other times once tilted it just stays tilted 😅 Quote Share this post Link to post Share on other sites
