Bandit 197 Report post Posted March 19, 2022 Recently fitted Koni Sportpaket shocks and new H&R springs being part of the kit. So lowered ride height 40mm Front 15mm rear. However, not a fan of the rake look now, any suggestions (short of replacing the H&R with Eibach) to either raise the front and / or drop the rear a tad more. Someone suggested E46 top hats (whatever these are) will raise the front a bit The suspension change certainly improved the handling and ride. And the fitting of a quick rack with help from M3AN is a plus too. Any comments welcomed. Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted March 19, 2022 Looks good to me. Spring perches\drop hats tend to used to lower not raise but maybe E46 ones would raise, im not sure. Are you running the thinnest spring pads in rear? Think they are 5mm Quote Share this post Link to post Share on other sites
