hot 520i 0 Report post Posted May 20, 2006 hi guys Im about to put a pod on to my 520i i just need to know what to do??? Im going to make a nice air box to go around it to as i know hot air is not good. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted May 20, 2006 As you say, keep hot air off it, so build a system around it that draws cool air from the front. Easier is probably to keep the standard airbox and replace the factory filter with a flat panel K&N filter and draw the air from the front as per standard.... imo pods are more hassle than they are worth.. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted May 21, 2006 keep the standard airbox and replace the factory filter with a flat panel K&N filter and draw the air from the front as per standard.... imo pods are more hassle than they are worth.. agreed.unless you need the extra air flow, ie if you have a massive turbo. Quote Share this post Link to post Share on other sites
Miller 0 Report post Posted May 22, 2006 "keep the standard airbox and replace the factory filter with a flat panel K&N filter and draw the air from the front as per standard.... imo pods are more hassle than they are worth.. " I agree aswell. I have just kept the standard box and replaced the filter with a k&n. Sounds great. Quote Share this post Link to post Share on other sites
