SIKE30
lowering 318i more
hi guys I have a e30 318i 1986 with chrome bumpers an i hav put lowering springs in it and i also changed tha shocks at the same time. But for some reason the front has lowered abit and the back hasnt!! Can some one tell me how i can drop the back more plz!!
post some pics...the pre Facelift have higher rear arches so if you are comparing to facelifts it may seem higher
give it a week or two to settle, as it may right itself
Mean. Rake looks good on euros. Could possibly be jamex springs, which do lower front more. Stop typing like an idiot as well. Type out in full otherwise some people will get annoyed, just some advice.
the springs and shocks need to settle.
also in the back you can remove the rubber spring pads that'll drop it an extra 10mm.
i never told you to do it though.
the springs are B & R or something they are red springs. Will taking tha rubber out cause any damage?
They are B & G springs. I find these are awesome for thug missions.
Let them settle for a couple of days. Then tell us if the problem is still there.
How low is it now?
put some pics up mate, otherwise simply compress them, as it will help your thug missions as mentioned by another member, and possibly give a 10hp gain due to the lesser wind resistance by the car being closer to the ground. think about it.
Edited by nz320i
i have the B+G red springs in my E30, they are 40mm lowering springs, my back dropped 30mm and front dropped 70mm (318 engine in 316 car = heavier)
has a really staunch stanch. mine is a facelift tho.
Yes, the B+G springs do settle slightly higher at the rear - well at least mine did anyway. You really shouldnt notice it unless the car is level. If you could post us a pic we could see exactly by how much you are talking about. As others have already said, they will settle somewhat. Heres a pic of mine with the same springs and Bilstein Sports
Edited by ducatiss
