hachwy 0 Report post Posted August 20, 2022 So I have a 2001 X5 E53 with a nav radio and want to install an aux cord. The videos I have watched explaining how to do It have a 3 pin plug behind the monitor that you use for the cord. When I took out my radio it doesn't have any extra plugs or cables behind it. Can anyone help me out? Is it at the back with the 6 disk changer? Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted August 20, 2022 The build date is important with the systems from 2001. I think the x5 / e38 / e39 & E46 gained the aux function either late 2002 or 2003. I don’t think yours is late enough to have the aux function. Hoverever , if you not fused with running cd stacker there are plug in units that replace the cd stacker and give you a combo of Bluetooth and analog/ aux type functionality. Quote Share this post Link to post Share on other sites
hachwy 0 Report post Posted August 20, 2022 35 minutes ago, Neal said: The build date is important with the systems from 2001. I think the x5 / e38 / e39 & E46 gained the aux function either late 2002 or 2003. I don’t think yours is late enough to have the aux function. Hoverever , if you not fused with running cd stacker there are plug in units that replace the cd stacker and give you a combo of Bluetooth and analog/ aux type functionality. Just took it out to have another look at it and it is 2001. Are the replacement units similar working to the aux cord input where I can plug in my phone to listen to music? Do you know of any? Quote Share this post Link to post Share on other sites
