tali
N54 Leaking oil
oil leaking any ideas on where this is coming from?took some pics from underneath the car any help would be greatly appreciated thanks
Sump gasket is best bet, look further up at rocker cover etc too
I agree with Chris
also check the oil filter and cooler housings for leaks.
Before you spend any $s, troubleshoot as best you can otherwise you may end up spending a lot of $s and time fixing something that wasn't broke.
Could even be a leaking oil feed from turbo/s? (but hope not)
