Toksis 3 Report post Posted January 23, 2023 Hello , what is the cause of this problem 2a59 and 2a67? Car sounds weird, and has intermittent cyclic rattle inside the car. I cleared it and it went ok after I just switch the car on without pressing breaks? Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted January 23, 2023 Valvetronic motor and sensor are the most common failure points but there are others. You'll need someone whos what they are doing to test\diagnose it properly. Otherwise you just have throw parts at it and hope. Also the right scan tool to re-calibrate the system it depending on what's replaced. It will probably cost 1\2 the cars value to fix if you are paying someone. Id just sell the car, they have too many problems. 1 Quote Share this post Link to post Share on other sites
325iRod 144 Report post Posted January 29, 2023 Agree with @Eagle, the valvetronic might need to be reactivated and put through the relearning process. Id suggest you download ISTA D and get a K+DCAN cable. 1 Quote Share this post Link to post Share on other sites
