zoom-motorsports
manual g box
no.
You need an M20 gearbox. Either a Getrag 240/260. Be careful though as some of the getrag 240's are made for the 4 cylinder engines not the 6 and you wont be able to use them.
Choose wisely, the 260 is the standard gearbox for the 325, you can use a 240 M20 gearbox but you will need to lengthen the drive shaft.
Transmission Type:__G240_______ZF S5-16_____G260
1st________________3.72__________3.72_______3.83
2nd_______________2.02___________2.04_______ 2.20
3rd________________ 1.32__________1.34_______ 1.40
4th________________1.00__________1.00________1.00
5th________________0.81__________0.80________0.18
R__________________3.45__________3.54_______3.46
With Loving thanks from the Bently Manual
