Funkyflynz 151 Report post Posted February 9, 2023 Hey all, just wondering if anyone has experience with the stop disk in the s50b32 vanos system? Im not sure if it needs to be replaced or where exactly it sits within the vano system, unfortunately when it came out i was a clown and didnt take a photo Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted February 9, 2023 Replied in the other thread, between the needle bearings and the circlip on the rear of the unit, it's of a size that it can't go elsewhere. I replaced mine with a metal one from the S54 but that's not necessary if yours is in good shape. Quote Share this post Link to post Share on other sites
Funkyflynz 151 Report post Posted February 10, 2023 7 hours ago, M3AN said: Replied in the other thread, between the needle bearings and the circlip on the rear of the unit, it's of a size that it can't go elsewhere. I replaced mine with a metal one from the S54 but that's not necessary if yours is in good shape. Thanks, yes it appears to be in good shape, but with everything apart im thinking it would make sense to replace it with a metal one and also do the circlip upgrade as well. Interesting that the plastic one seems to overlap…. Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted February 10, 2023 15 hours ago, Funkyflynz said: Interesting that the plastic one seems to overlap…. I don't think it should overlap but it's made of a pretty unsuitable material and easily deforms. Just make sure it's seated properly and it also has a little nub on it as an alignment guide... I don't think it really matters but check that this is also located properly. Quote Share this post Link to post Share on other sites
