SmackJackTheCrackerMan
Oil Pump - Snapped bolt
Hi all,
I'm currently doing some routine maintenance and changing my Oil pan gasket.
When I was putting the oil pan back on, half of a bolt dropped into the oil pan (see photo attached) not actually mine but the exact same situation
I have found a replacement bolt kit on FCP, but I'm not 100% sure exactly which one I require.
https://www.fcpeuro.com/products/bmw-screw-set-aluminum-11410426472#description
Includes the following bolts:
x6 11417529984 - Torx screw M8X31-AL - Oil Pump To Bed Plate - 10Nm + 90°
x1 13627530413 - Torx screw M6X16-AL - Chain Module to Oil Pump and Block - 4Nm + 45°
x1 11117528896 - ASA-Bolt M8X37-AL, AW - Bed Plate - 10Nm + 90°
x7 11137529982 - ASA-Bolt M6X20-AL,AW - Oil Deflector to Bed Plate - 4Nm + 90°
x4 11417529981 - ASA-Bolt M6X30-AL,AW - Oil Pickup to Bed Plate - 4Nm + 100°
x1 11417529983 - ASA-Bolt M8X123-AL-AW - Oil Pump To Bed Plate - 10Nm + 180°
