William Jacobsen 0 Report post Posted April 12, 2023 ABS and traction control not working, replaced wheel speed sensor did not fix the issue. Looked inside the hole where the sensor goes and a part of the disk hub is very crushed (in attatched image) Is this causing the sensor to not work? Quote Share this post Link to post Share on other sites
Harper 610 Report post Posted April 13, 2023 Almost certainly causing the sensor to read wrong and throwing errors. Usually more common on cars that get rusty there. Haven't done the fix myself but if you google E46 ABS ring replacement there are loads of threads that might be helpful. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted April 13, 2023 That looks like the rear wheel. The reluctor ring comes with the half shaft. There is a place in the states that sells just the reluctor ring so you don't have to go to the expense of a new half shaft. https://www.reluctorrings.com/ Try to work out how the damage occured, so it doesn't happen again with the new ring. Quote Share this post Link to post Share on other sites
