PeterA 0 Report post Posted May 15, 2023 Hi I've cleaned the front abs sensors on my e36 328i and now want to do the rear set. All I'm seeing in the brake pad wear sensor. Cant seem to see the rear abs sensors. Are these located further along the axle ? Thanks Pete Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 15, 2023 Basically on the opposite side of the caliper. You have to remove the wheel. Quote Share this post Link to post Share on other sites
PeterA 0 Report post Posted May 15, 2023 Thanks😀 Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted May 16, 2023 And pull the shaft if you want to deep clean the ring... Quote Share this post Link to post Share on other sites
