duluth 41 Report post Posted September 13, 2023 Hi there, I have an E39 530i 2001 with I believe a ZF transmission. Gave the car a wash this morning with pressure washer. Went to go to the warehouse and it shifts very badly. Clunked into reverse and then started slipping in 3rd gear. Gave it a scan with generic scanner and got code P0733 which is Incorrect gear ratio for 3rd. Any ideas? It was shifting perfectly before the wash as I had drove it this morning. Seems odd that it would do this right after washing it. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted September 13, 2023 You may have damaged or interfered with one of the wheel speed sensors with the water blaster. A generic scanner will not help you with this. You need to monitor live data to determine where the fault is. 1 Quote Share this post Link to post Share on other sites
