Cement 911 Report post Posted September 14, 2023 So at low speed when exercising the power steering i get a strange groaning noise some times ... sounds kinda like a piston binding in a bore then releasing or maybe fluid bypassing or similar ? This is my nissan power steering pump and OEM rack so its a bit of a hybrid solution ... i need a flow restrictor on the pump as its pushing way too much fluid causing a very light feel also. Ideas ? Noise is at the 8s mark in the video. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 14, 2023 Have you tried identifying the exact place the noise is coming from with a stethoscope? Quote Share this post Link to post Share on other sites
Cement 911 Report post Posted September 14, 2023 2 hours ago, *Glenn* said: Have you tried identifying the exact place the noise is coming from with a stethoscope? Sorry should have clarified it's intermittent and only when turning the wheel when stationary or moving very slowly as per the video ... assume high load on the hydraulic system. Quote Share this post Link to post Share on other sites
