Herbmiester 947 Report post Posted November 7, 2023 If you have a set of new, close to new or m3 front control arms I need a left and right set. Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted November 7, 2023 FWIW, try and hold out for the M3 ones, or see if you can source some TWR equivalents. Unless it's an urgent replacement you'll kick yourself if you buy stock ones then find M3 ones. I forget what they're called but the front upper arms are same length and material E8/9x = M3 with the exception of the bush which you can get poly replacements for easily enough, and then you actually end up with a better outcome than the M3 version. 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted November 9, 2023 Thanks Dave, yes I ran the M3 arms on my 335i and did notice the difference. I had wondered about doing the bushing on the tension arm and just buying the longer lower arm. It depends on what the tension arm's ball joint is like I guess. Quote Share this post Link to post Share on other sites
