topnotchrally 95 Report post Posted January 21 I was going to change the spark plugs on my 95 M3 but have been thwarted by 2 of the bolts on the cover. Some @$#@%#$ person put them on too tight and they will not come loose. Obviously, I have stripped the allen heads, what else could I do? My next thought it to try to drill off the heads but I thought I see if there were any better advice on how to get them off... Your thoughts please... Quote Share this post Link to post Share on other sites
Eagle 1524 Report post Posted January 22 Smacking a suitable size torx socket in and then using a manual impact driver would probably have it out easy enough. If you dont have impact driver have the driver then you can attempt with a ratchet. 3 Quote Share this post Link to post Share on other sites
