325_driver
2nd of problems
starting problem
car starts
after a few thousand cranks
batteries fine
when it finally starts, smells really really really rich
is this the problem ? its being flooded and wont ignite
the car can be warm and still have this problem
sound familiar ?
( some times when its cold it starts fine like one crank then spark )
ne suspicions
ne solutions to go with those suspicions
cheers guys
Could be dodgy air flow meter, also check plugs for oil. :( not fun when they dont work right aye. at least you have the early faster 325i
air flow meter is fine
plus are fine lol
every thing else is fine
what about a computer problem
or a base idle thingy ?
which almost acts as a choke u could say ?
ne one know
ne gurus here
You should double check the AFM...I had issues with mine doing somethign similar, along with reduced power, and bad fuel consumption, and white smoke when accelerating hard - switched over to a different AFM and all problems instantly resolved, even though my old one looked perfectly fine.
I'd suggest trying that...
Also before I crashed my car, I bought a brand new fuel pump and filter from BMW - that changed my start time from 5 - 6 cranks to 1 - 2 from cold. Could be something similar?
With the fuel smell present, it sounds like you may have sticky injector/s. Get a bottle of injector cleaner and put it in the tank and see if there is any improvement.
I have a f/l 320 at the moment that battles to start but runs reasonably ok once it has. I have diagnosed it down to the fuel pump but havn't put a new one in yet. Get your fuel pressures checked...
