Kees 646 Report post Posted January 31, 2024 Hi everyone, I’ve got an issue with my E34s climate controls (yet again). Having replaced the resistor sword and blower motor the climate control worked great for all of 6 days before I lost fan speed control again. (Fan only works on full) I removed my resistor sword (which was a working unit) and it still looks to be in very good condition and I can’t find anything wrong with it. I tried another resistor sword which was said to be working and still no luck… This leaves two possibilities: 1. both resistor swords which appear fine, are in fact buggered. 2. something else is causing loss of fan speed. I have also tried swapping the control panel with two others but no luck from that either. Is there anything else I should be looking at? The only other thing I could try is finding someone with an e34 to test whether the swords I have still work. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted January 31, 2024 my guess the sword these will all die maybe get it repaired by a electronic tech guy Quote Share this post Link to post Share on other sites
