bmwerks 2 Report post Posted February 22, 2024 Hey Guys Long story short, auto trans will go into "Drive" successfully for 20 meters or so and then there is nothing (essentially as if it is was in neutral), no matter how much gas you give. Some forums suggest torque converter as I understand the GM boxes are kinda trash. Is it worth getting diagnostics done first? - I'm assuming this is a gearbox out job. I really love the car and plan to keep it for a long time if possible. The car is otherwise in pretty great condition so may consider a manual swap for longevity. Anyone know how much realistically this would cost? TIA Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 22, 2024 330D uses it's own manual gearbox/driveshaft etc which might be a bit harder to find. Not sure they are interchangeable with a normal 330 manual box. Assuming you can find the parts for a 330d, manual swap probably costs 3.5-4k if you do the work yourself. Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted February 23, 2024 There’s a diesel zf box on FB now for $2300. 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 23, 2024 The cross member is cheap to buy brand new as well. https://www.schmiedmann.com/en/product/e61382-new?product=22-31-1-096-811 Just the have to find a 330d driveshaft 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 23, 2024 (edited) Roland actually has a complete 6 speed kit. You might be able to swap the rear half of your auto driveshaft onto this and you're good to go. I'd go this route personally. https://www.facebook.com/marketplace/item/7438401319514971/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A4aec2e64-4072-4f26-b9f5-e2f331e6f959 Edited February 23, 2024 by Harper 2 Quote Share this post Link to post Share on other sites
bmwerks 2 Report post Posted February 23, 2024 Legends - thanks guys ill have a look. Quote Share this post Link to post Share on other sites
