LsBeema 464 Report post Posted August 26 Surge tank, fuel lines, battery, wiring, radiator, oil cooler positioning & plans.. Rear mount radiator sounds great, electric water pump to help the cycle, will keep the engine & bay much cooler, and room for a turbo or 8 into 1 exhaust.. setup ...We'll see. 2 Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted August 27 (edited) Bled clutch and brakes, fitted d shaft, heat shield and exhaust. Once you jump in and out a few times...it's quite awrrite. Another feeling altogether sitting in this car. It's like the Ls was meant for a race spek like this.. 3.9 ratio diff in this one, with thicker shafts...last one was 3.15...so ...😳 Edited August 27 by LsBeema 5 Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted August 28 382949283bfe599c904d58f1c3e199c0.mp4 2 Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted October 2 Anyone has any time for sale...😑 A radiator bracket takes more that 3 weeks for fabricate. Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted November 22 Slow progress. 20241106_085754.mp4 20241113_140517.mp4 Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted November 24 (edited) VID-20241123-WA0001.mp4 VID-20241123-WA0000.mp4 VID-20241123-WA0000.mp4 Rear loose on 1st test drive.. Car feels sooo much more solid and planted now!! Had the tyre pressures at 36psi and feels abit too firm. Way too loose!! Alot of adjustments needed to the suspension to get the grip. The other 36, with no stiffening, even no strut bars planted the power down. One thing though, she darts straight ahead, no fish tailing. Exciting Build with full blown cage steup. Authority card next, then can start the cert inspection after she's ready. Edited November 24 by LsBeema 3 Quote Share this post Link to post Share on other sites
Cement 883 Report post Posted November 24 Sounds so good !!! Big part of me wishes I'd done a LS swap 1 Quote Share this post Link to post Share on other sites
LsBeema 464 Report post Posted November 25 Need to raise the rear. Windscreen fitted. Coolant Overflow next with Digital cluster and Can keyboard setup sourcing 1 Quote Share this post Link to post Share on other sites
