Herbmiester 947 Report post Posted April 14, 2024 I am still chasing down issues with the side impact sensor on the Z3. It was out of the car when i got it, and even after trawling through the internet and Real Oem, I can't work out where it actually sits in the car. The unit looks like this. Can anyone advise where it sits in the Z3? Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted April 14, 2024 It mounts under the seat. One each side. Remove the seat, separate the carpet at the split and find it mounted to the floor. They usually die due to water leaks, so if the foam under the carpet is wet, then you can expect the new one to die over time. 2 Quote Share this post Link to post Share on other sites
