Liiiam 2 Report post Posted May 19, 2024 Started about 2 weeks ago, obviously a shot in the dark but has anyone had the same/an idea of the issue? Also, any ideas of how much I could get scrapping this car? 20240519_165332.mp4 Quote Share this post Link to post Share on other sites
Eagle 1783 Report post Posted May 19, 2024 Cold start? Sounds like it could be a loose wastegate actuator arm which is a common rattle on these. If you remove the heat shield and O2 sensor can see and hold it with your hand to verify. There is VW rattle clip you can modify to fix the noise if its vibrating and causing the noise. Quote Share this post Link to post Share on other sites
