peter
tools
Hi Can anyone tell where I can buy the correct socket set and ring spanners that fit those fancy bmw bolts that hold my bell housing onto the block.
If you mean the "Torx" type that look like a star, I got my set from Trade Tools, Branches about the country, about 80.00 for the sockets. Both internal and external. And a allen key type set was about 25.00.
They are torx head. You need female torx sockets in two different sizes (I forget which two though - sorry).
Repco has them but not usually in stock - you have to order them. BNT sells tools - maybe they have them in stock but I doubt it.
E12 and E14?? just buy a set...powerbuilt ones through repco have done me fine
I bought the Powerbuilt set through Repco, they had to order it, took a couple of days, about $60 from memory, quality looks good too.
hah i got from bnt for 30 bucks if its only one job why bother spending heaps..
i wish most of the normal bolts where torx. they are so much better to work with.
Esp the drivetrain and suspension componets. Adjustment to the correct setting with these trox will be easier to achieve.
I bought a set of 8 sockets from a moblie tool truck for $70.
12 sided sockets will also remove these bolts, as opposed to the usual 6 sided ones.
