peter 0 Report post Posted June 11, 2006 Hi Can anyone tell where I can buy the correct socket set and ring spanners that fit those fancy bmw bolts that hold my bell housing onto the block. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted June 11, 2006 If you mean the "Torx" type that look like a star, I got my set from Trade Tools, Branches about the country, about 80.00 for the sockets. Both internal and external. And a allen key type set was about 25.00. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted June 11, 2006 They are torx head. You need female torx sockets in two different sizes (I forget which two though - sorry). Repco has them but not usually in stock - you have to order them. BNT sells tools - maybe they have them in stock but I doubt it. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 11, 2006 E12 and E14?? just buy a set...powerbuilt ones through repco have done me fine Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted June 11, 2006 I bought the Powerbuilt set through Repco, they had to order it, took a couple of days, about $60 from memory, quality looks good too. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted June 11, 2006 hah i got from bnt for 30 bucks if its only one job why bother spending heaps.. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted June 12, 2006 i wish most of the normal bolts where torx. they are so much better to work with. Esp the drivetrain and suspension componets. Adjustment to the correct setting with these trox will be easier to achieve. I bought a set of 8 sockets from a moblie tool truck for $70. Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted June 12, 2006 12 sided sockets will also remove these bolts, as opposed to the usual 6 sided ones. Quote Share this post Link to post Share on other sites
