bravo
Permanently remove longe range fuel tank
My latest acquisition has the long range fuel tank comon on the South African 325's. Problem - I don't need that kind of volume fuel tank, and it is right in the way of where I would like to mount a couple of amps. The factory boot lining would fit perfectly over them too as it is shaped to go around the tank.
Is it possible to remove then long range tank from the boot and easily seal off the feed from it to essentially revert to a standard setup? Presumably my fuel guage would be affected???
I would just rip it out and see, but thought maybe someone had some experience they could lend me.
badass...can i have it?
ask will...he's south african, and knows everything
I plan to - when I take him my starter to look at for you :P Y
I'm sure we can suss some sort of deal regarding the tank once I get it out.
Edited by bravomikewhiskey
