E30kid
N52B30 Parts
Hi all,
Have a parts motor from a 2007 130i at 130kms. Has a snapped retainer for the valvetronic eccentric shaft, snapped above an oil gallery so head is likely toast unless you can weld alloy well.
Motor was a mint runner until a job went awry, so everything works, is currently sitting on the subframe so everything is attached aside from a transmission.
Will likely keep a couple of pulleys as pretty sure the replacement motor needs one, however just ask whatever your after and I'll advise.
Woh. How did you manage that?
Didn't unwind the valvetronic solenoid before removing it, writing the engine off in the process. I know for next time!
Oh that's rough. It must have been fatigued already.
  • Like 1
Bump as starter/alternator/PS pump and manifold removed and now listed on TM. Will entertain any offers. Still have A/C pump/OFH/torque converter and subframe as well.
https://www.trademe.co.nz/4826188997
