joelwtk 0 Report post Posted November 13, 2024 (edited) Hi all, Currently have an E90 M-Sport with the stock style 194 wheels - 17x8J ET34 fronts and 17x8.5J ET37 rears. Stock tyre sizes are 225/45/17 fronts and 255/40/17 rears. Need new tyres for the rears - there's not many options for this tyre size out there, but looking at a tyre/wheel size calculator online, it says a 225/45/17 would fit my rears. I'm new to this, so would fitting a square tyre setup on a staggered rim setup even work? Alternatively, is there a different size tyre that would fit my rears? Cheers Edited November 13, 2024 by joelwtk Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted November 13, 2024 Check out Hyperdrive, seems to be plenty of options for that size. Alternatively, you could go 245/40R17 whilst retaining much of the tyre width. I wouldn't go 225 on a RWD car, not sure if they would work on a wider rim but hey, I'm not gonna tell you off either. 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted November 14, 2024 8 hours ago, joelwtk said: Hi all, Currently have an E90 M-Sport with the stock style 194 wheels - 17x8J ET34 fronts and 17x8.5J ET37 rears. Stock tyre sizes are 225/45/17 fronts and 255/40/17 rears. Need new tyres for the rears - there's not many options for this tyre size out there, but looking at a tyre/wheel size calculator online, it says a 225/45/17 would fit my rears. I'm new to this, so would fitting a square tyre setup on a staggered rim setup even work? Alternatively, is there a different size tyre that would fit my rears? Cheers You don't want 225/45R17 on the rear - it's a stretch. On the 8.5" wide rear you want the 255/40R17 as recommended. Why would you not want 255/40R17? Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted November 14, 2024 FWIW I run 245/40R17 on my rears, Style 194 on e46. it's the right circumference and fit for e46 staggered setup on Style 68. 245/40R17 probably the closest thing with a few more options than Bridgestone RE-050 runflats in 255/40R17. Unless you're running with a spare tyre, you will want runflats again. Another option is to get square setup rims and whatever the standard tyre size is for E9x with factory square setup. Quote Share this post Link to post Share on other sites
Phil 0 Report post Posted June 10 Hi @joelwtk what did you go for in the end and are you happy with them 6 months later? I need a replacement set and have the same wheels / tyre configuration that you posted. Thanks! Quote Share this post Link to post Share on other sites
joelwtk 0 Report post Posted June 10 12 hours ago, Phil said: Hi @joelwtk what did you go for in the end and are you happy with them 6 months later? I need a replacement set and have the same wheels / tyre configuration that you posted. Thanks! @Phil I actually didn't end up getting any - I passed WOF & have decided to most likely part ways with the car at the end of the year due to personal circumstances. I was planning on sticking to the stock size. My car still has runflats on & my fronts still have about 5mm left so I was planning on just biting the bullet and getting Bridgestone Potenza runflats - i.e. the only ones they have in that size. They're around $500 each. The other option would've been 4 new non run-flats and getting something middle of the range - there's some Nexen and Nankangs for about $200-$300 per tyre, so would've come out to about $1k too. Let me know what you end up going with. I'm going to miss my car. Quote Share this post Link to post Share on other sites
Phil 0 Report post Posted June 11 7 hours ago, joelwtk said: @Phil I actually didn't end up getting any - I passed WOF & have decided to most likely part ways with the car at the end of the year due to personal circumstances. I was planning on sticking to the stock size. My car still has runflats on & my fronts still have about 5mm left so I was planning on just biting the bullet and getting Bridgestone Potenza runflats - i.e. the only ones they have in that size. They're around $500 each. The other option would've been 4 new non run-flats and getting something middle of the range - there's some Nexen and Nankangs for about $200-$300 per tyre, so would've come out to about $1k too. Let me know what you end up going with. I'm going to miss my car. They are a great car! Mine is 2006 and just about to hit 84,000kms, so still has a bit of life in it yet. Ive decided against run flats, but will stick with the stock setup of 225/45/17 and 255/40/17. So far have received a quote for Nankangs but not really sure what else is out there at a similar price point. Anything around the $500/600 mark per tyre is feels excessive given the age and value of the car... Quote Share this post Link to post Share on other sites
