joelwtk 0 Report post Posted November 13, 2024 (edited) Hi all, Currently have an E90 M-Sport with the stock style 194 wheels - 17x8J ET34 fronts and 17x8.5J ET37 rears. Stock tyre sizes are 225/45/17 fronts and 255/40/17 rears. Need new tyres for the rears - there's not many options for this tyre size out there, but looking at a tyre/wheel size calculator online, it says a 225/45/17 would fit my rears. I'm new to this, so would fitting a square tyre setup on a staggered rim setup even work? Alternatively, is there a different size tyre that would fit my rears? Cheers Edited November 13, 2024 by joelwtk Quote Share this post Link to post Share on other sites
Vass 1031 Report post Posted November 13, 2024 Check out Hyperdrive, seems to be plenty of options for that size. Alternatively, you could go 245/40R17 whilst retaining much of the tyre width. I wouldn't go 225 on a RWD car, not sure if they would work on a wider rim but hey, I'm not gonna tell you off either. 1 Quote Share this post Link to post Share on other sites
Olaf 3405 Report post Posted November 14, 2024 8 hours ago, joelwtk said: Hi all, Currently have an E90 M-Sport with the stock style 194 wheels - 17x8J ET34 fronts and 17x8.5J ET37 rears. Stock tyre sizes are 225/45/17 fronts and 255/40/17 rears. Need new tyres for the rears - there's not many options for this tyre size out there, but looking at a tyre/wheel size calculator online, it says a 225/45/17 would fit my rears. I'm new to this, so would fitting a square tyre setup on a staggered rim setup even work? Alternatively, is there a different size tyre that would fit my rears? Cheers You don't want 225/45R17 on the rear - it's a stretch. On the 8.5" wide rear you want the 255/40R17 as recommended. Why would you not want 255/40R17? Quote Share this post Link to post Share on other sites
Olaf 3405 Report post Posted November 14, 2024 FWIW I run 245/40R17 on my rears, Style 194 on e46. it's the right circumference and fit for e46 staggered setup on Style 68. 245/40R17 probably the closest thing with a few more options than Bridgestone RE-050 runflats in 255/40R17. Unless you're running with a spare tyre, you will want runflats again. Another option is to get square setup rims and whatever the standard tyre size is for E9x with factory square setup. Quote Share this post Link to post Share on other sites
