DSNUTS 0 Report post Posted June 14, 2006 hey jst after a e36 diff 4.10 ratio and a left and right rear axiles if anyone has any cheap but relible txt me on 02102351986 cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 14, 2006 hey jst after a e36 diff 4.10 ratio and a left and right rear axiles if anyone has any cheap but relible txt me on 02102351986 cheers might have a 4.4 diff from 95 318i and rear axles . also have diffs from 97 z3 and 94 318ti ( they have e30 type rear mount but that can be swapped i think .and also rear axles from 320i , 320ci etc . 021433600 or 2997389 ah is best Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted June 14, 2006 I'll have what you want in about a fortnight, I'm doing a complete running gear conversion in my E36 [the 4.11 is coming out] Quote Share this post Link to post Share on other sites
DSNUTS 0 Report post Posted June 15, 2006 cool sounds good i will get back 2 u Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 15, 2006 might have a 4.4 diff from 95 318i and rear axles . also have diffs from 97 z3 and 94 318ti ( they have e30 type rear mount but that can be swapped i think . and also rear axles from 320i , 320ci etc . 021433600 or 2997389 ah is best Hi there Brent....is the 97 Z3 diff a small casing ???? if so, what ratio is it ???.... I'm after a 3.91 small casing diff for my 318TI (2.8L) Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 17, 2006 might have a 4.4 diff from 95 318i and rear axles . also have diffs from 97 z3 and 94 318ti ( they have e30 type rear mount but that can be swapped i think . and also rear axles from 320i , 320ci etc . 021433600 or 2997389 ah is best Hi there Brent....is the 97 Z3 diff a small casing ???? if so, what ratio is it ???.... I'm after a 3.91 small casing diff for my 318TI (2.8L) call me sunday pm on monday .yes small case ., will have to check the ratio , sounds about right . 021433600 or 2997389 Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted July 4, 2006 I'm getting the E36 4.10 diff & axles out this friday 7th july, if you're still interested. Tried TXTing you but your number you gave has too many digits Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 4, 2006 I'm getting the E36 4.10 diff & axles out this friday 7th july, if you're still interested. Tried TXTing you but your number you gave has too many digits Kerry: Is it medium case? Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted July 5, 2006 How can I tell for sure [While it's still in the car] I visually checked it out ,It seems about the same size as my 328 head [They all look small to me, compared to Corvette diff heads] Quote Share this post Link to post Share on other sites
