Gaz 1077 Report post Posted February 9 Fs: complete m62b46 - if you are going v8 then this is one you want. Out of an x5 4.6is done around 205km, has a few oil leaks as expected. Also comes with 5/7 series oil pump and a non vanos lower timing cover so you can fit a standard alternator which is needed for clearance in you e36/e46. Hoping for 5k.. Selling as opportunity to go 1jz has appeared Christchurch 2 Quote Share this post Link to post Share on other sites
mercenary 2 Report post Posted April 5 Do you still have this ? Txt me 021889960 thanks Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted April 5 14 hours ago, mercenary said: Do you still have this ? Txt me 021889960 thanks Done Quote Share this post Link to post Share on other sites
Kodachrome 177 Report post Posted July 24 Not going the S54 route anymore? Or did you loose your lotto ticket to afford the damn thing! 1 Quote Share this post Link to post Share on other sites
turboray82 50 Report post Posted July 24 Shoot i'd be a had sell to go away from a 1J. Bomb proof Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 25 21 hours ago, Kodachrome said: Not going the S54 route anymore? Or did you loose your lotto ticket to afford the damn thing! To be fair, initial post is from February when there was a 1jz but the more I think about about the more I just want something easy to pop in and drive. I'm all for the journey but I'm at the point where I just want to drive and not spend time f**king around making sh*t fit Quote Share this post Link to post Share on other sites
Kodachrome 177 Report post Posted July 26 On 7/25/2025 at 12:37 PM, Gaz said: To be fair, initial post is from February when there was a 1jz but the more I think about about the more I just want something easy to pop in and drive. I'm all for the journey but I'm at the point where I just want to drive and not spend time f**king around making sh*t fit This is my conundrum too. I still have my eye on M62B46's, as you put its the next most interesting option, but I just checked and the custom engine mounts and wiring harness I had bought/made means an S54 is nearly a drop in replacement instead of the M54 thats in there. Quote Share this post Link to post Share on other sites
