Gaz 1077 Report post Posted February 9 Fs: complete m62b46 - if you are going v8 then this is one you want. Out of an x5 4.6is done around 205km, has a few oil leaks as expected. Also comes with 5/7 series oil pump and a non vanos lower timing cover so you can fit a standard alternator which is needed for clearance in you e36/e46. Hoping for 5k.. Selling as opportunity to go 1jz has appeared Christchurch 2 Quote Share this post Link to post Share on other sites
mercenary 2 Report post Posted April 5 Do you still have this ? Txt me 021889960 thanks Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted April 5 14 hours ago, mercenary said: Do you still have this ? Txt me 021889960 thanks Done Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted Tuesday at 09:20 AM Up Quote Share this post Link to post Share on other sites
Kodachrome 171 Report post Posted Thursday at 02:42 AM Not going the S54 route anymore? Or did you loose your lotto ticket to afford the damn thing! 1 Quote Share this post Link to post Share on other sites
turboray82 42 Report post Posted Thursday at 02:45 AM Shoot i'd be a had sell to go away from a 1J. Bomb proof Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted yesterday at 12:37 AM 21 hours ago, Kodachrome said: Not going the S54 route anymore? Or did you loose your lotto ticket to afford the damn thing! To be fair, initial post is from February when there was a 1jz but the more I think about about the more I just want something easy to pop in and drive. I'm all for the journey but I'm at the point where I just want to drive and not spend time f**king around making sh*t fit Quote Share this post Link to post Share on other sites
Kodachrome 171 Report post Posted 10 hours ago On 7/25/2025 at 12:37 PM, Gaz said: To be fair, initial post is from February when there was a 1jz but the more I think about about the more I just want something easy to pop in and drive. I'm all for the journey but I'm at the point where I just want to drive and not spend time f**king around making sh*t fit This is my conundrum too. I still have my eye on M62B46's, as you put its the next most interesting option, but I just checked and the custom engine mounts and wiring harness I had bought/made means an S54 is nearly a drop in replacement instead of the M54 thats in there. Quote Share this post Link to post Share on other sites
