130iGuy 0 Report post Posted February 20 Hi Guys! Newbie here. I’ve been lurking in the Bimmersport forums for a while now, mostly using it as a reference to troubleshoot issues myself. However, I’ve hit a brick wall with my headlights—lmao. A Bit of Backstory I bought my car (2006 E87 130i) a couple of years ago, and all was well. Then, a job opportunity came up in the South Island, which I took. Since the job came with a company car, I decided to leave the Bimma at home for when I returned. It has been driven occasionally to keep it from sitting, which is great, but since coming back, I’ve run into an issue with my low beams and halos. The Issue I have bi-xenon headlights, and the problem started with one low beam going out, followed by the halo on the same side. I replaced the xenon bulb, which fixed it for a few months, but then the low beam started flickering on and off. Now, neither the halos nor the low beams work on either side. What I’ve Tried So Far • Replaced all headlight-related fuses in the fuse box. • Bought a new ballast to test if that was the issue, but the lights on that side still don’t work. Possible FRM Issue? From my research, I’ve seen that it could be an FRM issue. I’ve read that if the FRM detects over 50 faults, it shuts off power to the affected module (if that’s true and not just a myth—lol). If that’s the case, then I’ve definitely hit that limit. However, I don’t seem to have any other FRM failure symptoms, so I don’t think the entire module has failed. If an FRM reset is needed, does anyone here have Tool32 software and would be willing to help a brother out? Or could someone point me toward a trustworthy shop that can reset it? I’d rather not go to a shop if I can avoid it—I love learning and fixing things myself. Every issue I’ve encountered so far, I’ve been able to sort out, but this one has me stumped. If anyone has had a similar issue or knows the fix (or at least the pathway to fixing it), I’d love to hear from you! Ps. I work in the liquor industry so would be more than willing to sort someone something out for helping me. Thanks in advance! Let me know if you need any additional info like vin etc Quote Share this post Link to post Share on other sites
Jacko 2404 Report post Posted February 20 (edited) Heya mate, Definite FRM issue is likely. I have protools which might be able to do it (Ive done it before, but cant remember what I used as was awhile ago). My laptop running all the BMW software shat itself and I haven't reinstalled it all again on the new one yet, should probably do that. Welcome to shoot around and can plug it in and see if can deal with it. Im in south auckland and currently around most of the time - 0210729458 Edited February 20 by Jacko 1 Quote Share this post Link to post Share on other sites
Driftit 2253 Report post Posted February 20 FRM. Mine do the same on occasion. I've had mine repaired but they eventually corrupt or fail again. Due to their location they corrode. Especially during wet weather. Quote Share this post Link to post Share on other sites
