Petrie 0 Report post Posted July 25 Hi all. New to here so apologies if this has not already been covered...sure it would have. I have a headlight vertical aim control failure fault coming up. On top of that my daytime running lights on LH headlight do not work not to mention, what I have found out is a common problem, leaking headlights!! Local auto sparky gave me a price of $8k to sort these issues out. Half the value of the car!!! Has anyone out there managed to repair these using aftermarket parts or by any other means. I am reasonably handy being an ex mechanic but this car is not a 1965 mini!!! Any advise would be appreciated. Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted July 25 yea they all leak kills the modules etc i think there are some companies that reseal them ? otherwise ring bmworkshop for price on new ones i think about $2k-2500 new each ? Quote Share this post Link to post Share on other sites
M3AN 4203 Report post Posted July 26 @Petrie - I'm not sure if it's the same fix, even if it's the same problem but the E series cars have this problem also, the "fix" is to remove the headlamp and drill drainage holes where they fill up with water, dry everything out, and reassemble. Front bumper possibly has to come off. If you catch it early enough you can save the electronics and avoid costly replacements. Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted July 29 I do have this coming up as the next one to tackle, will need to either get a smoke machine or create one myself. This is an example, not exactly the same car but same hassle: Quote Share this post Link to post Share on other sites
M3AN 4203 Report post Posted July 29 48 minutes ago, 318Touring said: I do have this coming up as the next one to tackle, will need to either get a smoke machine or create one myself. This is an example, not exactly the same car but same hassle: I think that's a different type of leak, the condensation typically doesn't interfere with the electronics as seems the case with the OP. Regardless, it's also important to rectify any condensation issues! Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted July 29 13 hours ago, M3AN said: I think that's a different type of leak, the condensation typically doesn't interfere with the electronics as seems the case with the OP. Regardless, it's also important to rectify any condensation issues! I wish it was only condensation! This F types have been known to fail WOF because water was dripping and running down the inside of the headlights. Actually, when mine went through its WOF last month, the tester said it would've failed if the leak had been just slightly worse than it was. 1 Quote Share this post Link to post Share on other sites
M3AN 4203 Report post Posted July 30 Wow, so they're worse than the E series lights! 🤨 Is it the gasket between the lens (is it really a lens?)/housing failing? Quote Share this post Link to post Share on other sites
318Touring 40 Report post Posted July 31 On 7/30/2025 at 12:46 PM, M3AN said: Wow, so they're worse than the E series lights! 🤨 Is it the gasket between the lens (is it really a lens?)/housing failing? Gasket/sealant, unfortunately BMW haven't been making long lasting products for a while now. Quote Share this post Link to post Share on other sites
