Brad1138 0 Report post Posted June 28, 2006 Hey, Just had my e34 lowered, in my opinion its no where near low enough. 3cm in the front, nothing in the back. basically looks standard. wondering what you guys have done to get more drop, saw off a coil or compressing the springs? it rides basically the same aswell. im pretty dissapointed. what else can i do? thanks for the help in advance. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 28, 2006 should look something like this Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 28, 2006 low Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 28, 2006 very low when towing 2 tons Quote Share this post Link to post Share on other sites
Brad1138 0 Report post Posted June 28, 2006 yeah its the same height as the first one pretty much, you know any tricks to get it lower? aparantly if the springs are any smaller they become uncaptive. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted June 28, 2006 If yo want lower springs and captivity is a problem then you need to also purchase shortened shocks so as to limit the suspension travel. Lopping off a coil (DON'T!!!!) or compressing the spring (generally not recommended) will give the same problems regarding captivity as shorter springs. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted June 28, 2006 Makita one way adjustables!!!! Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 29, 2006 yeah its the same height as the first one pretty much, you know any tricks to get it lower? aparantly if the springs are any smaller they become uncaptive. do you want a hole in the sump? Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted June 29, 2006 do you want a hole in the sump? haha fully. Feel my burn etc. A thin alloy brick that hangs down in front of the crossmember = one of the pain in the arse m30 designs Quote Share this post Link to post Share on other sites
Brad1138 0 Report post Posted June 29, 2006 I dont think hitting the sump is a problem at all, its still 16cm above the ground. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted June 29, 2006 hah, thats ok, thats what mine was before owering with the standard 20mm drop mtech springs, is now 80mm off the ground with the jamexs, hah. Quote Share this post Link to post Share on other sites
