kerrynzl 3 Report post Posted July 4, 2006 Anybody out there in Bimmerland know the Torque Settings for a manual flywheel & pressure plate for a M50 Engine [Foot / Pounds] Also where can I get [buy] the sockets for those 6 point cap-screws [bellhousing bolts & rear CV's] Chairs [Cheers] Everyone Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted July 4, 2006 power built make kits of those stare sockets etc , from repco or ,most tool and engineering shops . will get back to you about the torque settings , i have a manual , buts its late and its in the garage . thanks for dropping off the gearbox . ps. what year and millage did the car it cam efrom have . cheers brent Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted July 4, 2006 I was told 1990 E34 ,Mileage I'm unsure Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 5, 2006 FT for the flywheel, in the right order, with locktite not so FT for the PP...they allen bolts anyway, weak as hell Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted July 5, 2006 Hey Gus, slight misunderstanding .I'm after the Torque settings in Foot/Pounds or Inch/Pounds [because My old W&B Torque Wrench is Imperial] If someone can only supply the figures in Newton/Metres it will do I aggree with You about Flywheel & PP bolts [i've seen 'em come off too many times] I always Torque them Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted July 5, 2006 Gidday Kerry Here is what the manual says: Flywheel to crankshaft 105 Nm (77 ft-lb) Pressure plate to flywheel M8 8.8 Grade 24 Nm (18 ft-lb) M8 10.9 Grade 34 Nm (25 ft-lb) This help? Good to meet you the other day as well, hope my wonky directions got you onto the motorway ok. Cheers Grant Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted July 5, 2006 Thanks for that Grant, Yeah those directions were OK Quote Share this post Link to post Share on other sites
westy 614 Report post Posted July 7, 2006 Ha. Seems we have 2 of these happening at the same time .Woot. BMWs the way god intended Quote Share this post Link to post Share on other sites
