buzzlightyear 0 Report post Posted July 16, 2006 just recently did 325i conversion then later on will be turbo charging it. when i first got it in it really seemed like a weapon in the wet not it just seems really slow like something has shat it self. my friend also has noticed the huge drop in performance rather frustrating! just wondering is this common or does anyone know what the hell this drop in performance is? any help be really appreciated and any info on turbo charging be awsome too cheers. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted July 16, 2006 yeah it's your main cog, it's busted man. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 16, 2006 could be any number of things as for turbo, go to www.e30tech.com, dont ask questions, just read. and read. there enough material there to answer nearly all questions you may have...at least with more info you can be more informed to ask intelligent questions. m20s love turbo. what you mean drop in performance? just all round? not you getting used to it? wear items? Quote Share this post Link to post Share on other sites
DCEIVN 0 Report post Posted July 16, 2006 is it over the whole power range? or just low revs or just high revs? Quote Share this post Link to post Share on other sites
topless 14 Report post Posted July 16, 2006 check that your timing belt isn't a tooth out and check for air leaks into the manifold eg cracks in large intake rubber behind air flow meter etc and check air flow meter operating properly, swap with another if possible, but really could be all sorts of other things too. Start with the timing belt though.. if it is losing teeth or loose and jumping teeth you could end up with a terminally ill engine! Will Quote Share this post Link to post Share on other sites
buzzlightyear 0 Report post Posted July 19, 2006 im a muppet i checked some things and all it was ,was three loose spark leads from the distrubutor. going back to its normal self. guess its what happens when your qualified diesel mechanic. Quote Share this post Link to post Share on other sites
