E30stz 0 Report post Posted August 14, 2006 use this tutorial to see how to get to the rear of your intrument cluster, note: they use a 6 star screw. then just swap bulb over and refit the cluster. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 14, 2006 The offset should be OK, but they need to be 4-stud (4x100). Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted August 28, 2006 (edited) Anyone know if the rear seats out of an E36 coupe will fit into a E30 coupe with little or no modification. Do they mount hte same way ? If anyones willing to grab some basic dimesions that would be awesome. Am I better to try fit E30 brackets onto E36 coupe front seats or mod the current rails. Edited August 28, 2006 by E30stz Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted September 1, 2006 do E30 fuel tanks have anti-syphone mechanism's to stop me pumping out hte petrol? Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted October 9, 2006 Gah ~ is the BMW Model number all one needs to get the right parts for their car? All the rest is in Jap. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted October 12, 2006 Anyone ^^ ? Also, the only way to legally remove the center "hella" brake light would be to replace with another eh'? A LED brake light in the spoiler sufficient? Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 12, 2006 You would probably need to quote the E-code (eg. E36 E34 E30 E38 E39 etc etc.), the year, possibly whether its a facelift or pre-facelift model and maybe the VIN number that should be stamped either in the inside of hte drivers door or in the engine bay either below the windscreen or stamped onto a plate above the headlights on front drivers side in the engine bay. Something to take into consideration is there may not be a LED brakelight spoiler for your model, the ones you may have seen could be aftermarket or non bmw. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted October 12, 2006 Hey thanks, completely forgot about searching the door. Duhh. Ah, so its still a legal requirement to have a secondary brake light in the centre of the car? I have an e30, haven't seen any. Wouldn't mind cutting up an aftermarket spoiler, see how it goes? Guess I could talk to a WOF person eh'? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 13, 2006 You have to have the centre light if your car was first registered in NZ on or after 1/1/1990 so all e30 imports imported after this date and some nz new cars have to have them. The date your car was first registered is shown on the rego sticker as a month/year in smallish print lower right hand side of the sticker. Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 13, 2006 (edited) E30 Leaks - what would cause a leak that would take on water in the passenger side footwell .. it seems to be coming from the back not hte front. Any idea how to combat this. Also some dampness in rear passenger side well. Edited October 13, 2006 by E30stz Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 14, 2006 Check this thread Andy. http://www.bimmersport.co.nz/forums/index....22&hl=leaks Quote Share this post Link to post Share on other sites
antony 0 Report post Posted October 14, 2006 hey. ive got a 1990 e30 320i And the anal vtnz guys wont give me a wof with my brake pad light on the dash staying on. Ive had a look and the wires shot. Where it runs down the suspension strut. But the question is how do i replace it or turn that light off. Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 14, 2006 Easiest way is to pull the instrument cluster out and remove the light. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 14, 2006 Easiest way is to pull the instrument cluster out and remove the light.no way, thats a missionthe brake pad sensor is a constant circut and when the brakes where down the sensor is split in half resulting in the light coming up, just cut the wire for the sensor under the wheel arch and wire the two little wires inside together, tape it up and no more light. you can easyily replace it later so no big deal, take the wheel off front left, and rear right for the sensors Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 14, 2006 (edited) if you cut the wire, wouldnt it still be a broken circuit ? Taking the bulb out of hte dash is not that hard really and it wont cause any permanent damage to the car. Takes about 15mins to do with no special tools just a flat head and phillips head screwdriver and a 22mm socket which you'll probably need to go buy. and your sweet (possibly some needle nose pliers See here, its a sinch. Edited October 14, 2006 by E30stz Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 14, 2006 C'mon, it's 10 mins max, easy as. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 14, 2006 (edited) if you cut the wire, wouldnt it still be a broken circuit ?if you cut just above the sensor and wire the 2 wires toghether, a bit of duct tape, no permanant damage becuase the sensor unplugs further up to replace it.cant say ive tried removing my instrument cluster in my E36 but i know itll take longer then 10mins, cables and clips and all that crap then find the right bulb to remove. weird that it caused you to fail your warrant thoe, i flew through a warrant at VTNZ with my brake warning light up, changed the pads a few weeks after and cut the light out. Edited October 14, 2006 by MADBMA Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 14, 2006 hes got an E30, much more DIY mechanic friendly. Quote Share this post Link to post Share on other sites
blk320i 0 Report post Posted October 15, 2006 need help with plug. 1990 320i coupe. while mucking aroung with my central lock unit in the drivers footwell i noticed there are are few plugs in there not plugged into anything. one is black and about 3cms by 3cms. and there are two smaller white ones. what are these for and what do they plug into? thanks Quote Share this post Link to post Share on other sites
low320i 0 Report post Posted October 20, 2006 hay finally got the bit to get my 87 e30 back together but now the drivers door lock is playing up. it unlocks fine you carnt lock it with the key full stop and you can only push it down from the inside when the door is shut. iv pulled the door card off and found alittle spring lying in the bottom of the door and the back of the lock seems pretty worn out just woundering does anyone have some pics or know how the spring is spose to go back together Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted November 2, 2006 Ok here's a quicky.. car: e36 coupe today drivin round 10ish goin home.. turned on heater (two nobs in middle max to right and that switch under the centre fan exhaust on 3 red) ... and waited 5 mins to get me toasted up.. and i got home I WAS STILL FREEZIN MY ASS OFF !!.. the engine temp was at 1/2 way.. what gives?? !! makes me want my honda back LOL Quote Share this post Link to post Share on other sites
sadida20 0 Report post Posted November 20, 2006 Hey guys I have a e36 97 323 coupe it was running MINT till last week . Now it wont turn over.. just makes a funny noise like when a compression test is done.. like wants to start but cant. wondering if anyone knows what it could be? sparks? fuel? THANKS Greg Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted November 20, 2006 You mean like a fast ticking sound? Flat battery my friend. Solenoid on starter not engaging properly as not enough juice. Ok here's a quicky.. car: e36 coupe today drivin round 10ish goin home.. turned on heater (two nobs in middle max to right and that switch under the centre fan exhaust on 3 red) ... and waited 5 mins to get me toasted up.. and i got home I WAS STILL FREEZIN MY ASS OFF !!.. the engine temp was at 1/2 way.. what gives?? !! makes me want my honda back LOL Faulty heater core maybe? Quote Share this post Link to post Share on other sites
sadida20 0 Report post Posted November 20, 2006 Hey guys I have a e36 97 323 coupe it was running MINT till last week . Now it wont turn over.. just makes a funny noise like when a compression test is done.. like wants to start but cant. wondering if anyone knows what it could be? sparks? fuel? THANKS Greg Hi it still makes the sounds of it wanting to start. But just want turn over?/ Hi it still makes the sounds of it wanting to start. But just want turn over?/ sorry but vehicle still has power. windows etc.should i charge battery and see. THANKS Quote Share this post Link to post Share on other sites
318isCoupe 0 Report post Posted November 20, 2006 Hi it still makes the sounds of it wanting to start. But just want turn over?/ sorry but vehicle still has power. windows etc.should i charge battery and see. THANKS Charge battery, sandpaper/file the battery terminals and clamps, and make sure they're done up tightly. Quote Share this post Link to post Share on other sites
