Jonty m50e30 0 Report post Posted September 14, 2006 gidday folks yep took a hit in the side while facing the wrong way at manfeild last weekend, so I need a right hand side trailing arm as it is bent, oh and when the car then backed into the wall I broke the tail light so I need one of those also for a preface lift. any help is appreciated. Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 14, 2006 have rear arms $150 plus fr8 . cheers brent 021433600 Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted September 15, 2006 (edited) I'm not sure if discs / drum trailing arms differ or which you have but can do one for $85 + pickup/delivery Edited September 15, 2006 by E30stz Quote Share this post Link to post Share on other sites
2002 1 Report post Posted September 19, 2006 I'm not sure if discs / drum trailing arms differ or which you have but can do one for $85 + pickup/delivery E30 disc trailing arms are different to drum trailing arms, the drive shafts & bearings seem to be different as well Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted September 19, 2006 Yep no caliper mounts on the drum arms, so I will need a disc one, shafts are the same as the ones on my car were originally from a drum rear end. e30stz I will PM you. Brent I will give you a shout if I still need one. cheers. Quote Share this post Link to post Share on other sites
