TronSpec
Custom Intake For my m50 e30 swap
Was feeling pretty proud of myself after this...............
I've never attempted constructing this sort of thing as I've also had a pretty good paying job so just paid kunt's to do it
Parts: 2x 3" mandrel bends stainless
3x rubber silicone joiner's &
Hose clamps
1x K&N Filter
Had to do a bit of measuring and cutting to make the bends fit, hole sawed a 3/4" hole and welded small tubing to base of the bend coming off the throttle body for a vaccum line. Plumbed off the vac hose for the charcol filter and made up a catch can for the block oil bleed off hose. All up I think this cost me about $180 plus about 6hrs to fit it all.
f**k these hiny's are going down well.......... time for a joint :ph34r:
Note: pic's are during fitting hence why everything ain't hose clamped up
Edited by MrHamWallet
nice job.
did you do a write up on the conversion?
if not could you? would be very helpful.
Edited by 325GRANT
um yeah bro a little while back
With picturres to
Had a look back in the forum and look's like it's being deleted with all the server swaps
I''m a bit pissed at the mo so will do a bit better write up with pics' at some stage :drunk: :drunk:
Seems a few of the boy'ds and maybe girls are thinking about doing he swap aye....... :ph34r:
I'll have a complete 70k M50B20 for Sale complete with Loom'n'puter as soon as I can get motivated to chuck the 2.8 in my car
[if anyone is interested,and is willing to wait a while ,contact me]
Also; Nice Job with the Manifold!
Just being looking on the R3v forums where I posted pic's of my intake and they metioned that I can't have a bend before my airflow meter as it cause's turbulance and it won't get accurate readings.
Can anybody elaborate on this??? Do you need to have straight pipe before the AFM??
They also mentioned breather lines.... What are these and where do I need to put them??
Bare in mind I'm still using the stock ecu :ph34r:
Here some pics of it all completed.
I've installed a oil catch tank to eliminate the oil breather line.
I've done a 3/4' burst perfuration and welded a pipe just on the under side of the intake for the main vaccum hose and plumbed off the evaporater purge valve vaccum line.
As for the bend before the HFM.... I have posintioned the fin's at the top of the pipe where the concentrated air will be..
I'm currently coming up with a heat shield and have pinched some dryer ducting for directing the air onto the filter...
