kerrynzl 3 Report post Posted October 10, 2006 Little problem here, The Sunroof on my E36 has died. I probed it with a multi-meter, and there is no power at the fuse Now,behind the fuse, there is two wires a Red/purple stripe that goes to the Sunroof and a Red/yellow stripe that goes to a power source somewhere Does anybody know where the other end of this power wire goes to [it goes thru the firewall] or should I wire it Direct to the battery [at the fuse box]as an easy fix cheers everyone. . . . . .Kerry Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 10, 2006 Car year and model might help Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted October 11, 2006 Car year and model might help OOPS! 1993 320i Coupe Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 11, 2006 i have complete mech from a coupe Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted October 11, 2006 i have complete mech from a coupe Thanks for the offer Brent! My sunroof works OK if I bridge the fuse from another power source in the Fuse-box. I just need some Info on where the power source for the Red/yellow stripe wire comes from.[eg; a relay that is controlled by a delay or whatever] this wire goes thru the firewall if it is a relay, where is it? Regards Kerry Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 11, 2006 You'll have a dead relay for sure. Read here for relay location and diangosis: http://www.bmwnut.blogspot.com/ Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted October 11, 2006 does it hurt to wire this live? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 11, 2006 Here's more info on the comfort relay that fails: http://bimmer.roadfly.com/bmw/forums/e36/8001720-1.html and more info here as well http://www.unixnerd.demon.co.uk/bmw_e36.html Easy to fix Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted October 11, 2006 If the comfort relay is Toast, wouldn't that affect my windows as well ???[mine are working fine] Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 11, 2006 does it hurt to wire this live? aslong as its fused it wont make a difference, just do it and if you have any problems with any other eletrics in your car go back to it, but i think you should be ok to wire it live, i cant find a diagram for your car with a red/yellow wire going anywhere round it, according to the diagrams i did look at thoe its just coming straight from the power distrubution block and fused then the red/purple stripe to your sunroof, my geuss would be that the red/yellow wire is going to a relay that is switched by the ACC power alowing the constant 12v through, you can bypass the relay with a constant 12v just make sure its fused and your sunroof will work at all times when car turned off. Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted October 12, 2006 I found the 'comfort Relay' behind the Glovebox [ the red/yellow is fed from it] I bridged from the Red to the Red/Yellow via an inline fuse with spade terminals ,The Sunroof now is working OK [i'll try and get a relay tomorrow] Thanks everybody on this forum for the help I got Quote Share this post Link to post Share on other sites
