SIKE30
Unstable idle
Hi I have a 1986 318i with a m10 engine. For some reason the engine does not idle steady. It revs back n forward from 800 to 1000 rpm.
I have changed HT leads, Dist.rotor, Dist.cap, Spark plugs, The head gasket has been changed not so long ago and the head was reconditioned. I am pretty sure there are no vaccum leaks.
It does this at normal operating temperature and sometimes when engine is cold. (could a coil cause this?)
Please help me. Thank you
Idle control valve??
ICV or TPS, do a search on the previous threads to found how to resolve it
Go up the top and click on search
Edited by Carl
This topic is now closed to further replies.
