blk320i 0 Report post Posted October 12, 2006 (edited) so tihis was sitting in the boot of the 90 e30 coupe i brought and was wondering was it is? where it goes? on the top it has numbers etc: 007 201 bmw sachs 519 61.31 1 380 302 http://i57.photobucket.com/albums/g203/v800/end.jpg http://i57.photobucket.com/albums/g203/v800/top.jpg thanks Edited October 12, 2006 by blk320i Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 12, 2006 It's the central locking module - locates lower drivers side kick panel Quote Share this post Link to post Share on other sites
blk320i 0 Report post Posted October 12, 2006 sweet, thanks. will try it out tomorrow Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted October 12, 2006 OHHHH bad times with the old module..got quite intimite with about 4 of them and it didn't work out with any haha You gotta take the right speaker out and theres a push out plate and its under there. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 12, 2006 They should ask questkions like that on the BMW nerd test. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 12, 2006 They should ask questkions like that on the BMW nerd test. ha ha, i was quite suprised there wasnt the question "are you a member of a online BMW forum" Quote Share this post Link to post Share on other sites
blk320i 0 Report post Posted October 12, 2006 (edited) so i plugged it in and the central locking still doesnt work. but i did notice another big black plug and a couple of smaller white ones that are not plugged in to anything, does this have anything to do with the central locking? if not what are they for? Edited October 13, 2006 by blk320i Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 13, 2006 a common problem that stops the central loking from working is the plug that take the cabling fom the drivers door into the car (front kick panel) pull out the plug and clean the connection thoroughly. water gets in it over time and corrodes the connecions. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted October 13, 2006 did ya ever think that the central locking module was stuffed originally and taken out by the previous owner and thrown into the boot to oneday be replaced? id say it was already stuffed thats why it was taken out and you might have to get another one, just my geuss. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 13, 2006 Here it is: http://www.realoem.com/bmw/showparts.do?mo...fg=50&hl=81 You were looking at item #17 bolted to bracket #18 Central locking should be easy to fix. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 14, 2006 The modules are known to fail, also check terminals for corrosion & clean if required, as already said - check terminals in drivers door jamb plug for corrosion. If you need another module - I have one here: http://www.trademe.co.nz/Browse/Listing.aspx?id=73721461 Quote Share this post Link to post Share on other sites
blk320i 0 Report post Posted October 16, 2006 all fixed. i cleaned all the connections etc and now she goes. Quote Share this post Link to post Share on other sites
