speakeasy 0 Report post Posted March 18, 2004 (edited) okay. this is the deal. had a strange "woowoowoo" from my front right wheel, so i thought it was the bearing... on closer inspection there was no play in the wheel, and no vibrations through the spring/shock so bearings were ruled out. then i noticed excessive brake dust.... got the car up on a hoist and found the wheel in question not to be spinning freely. aha! siezed caliper... but no took the caliper apart, not the problem... sure, i could just take it to a mechanic, but im pretty keen to get to the bottom of it... has any one got any ideas??? shes got abs... could this be the cause? how can i find out? brake fluid levels are sweet too. it also had uneven wear on the pads... one was a good 5mm worn than the other... thoughts? Edited March 18, 2004 by speakeasy Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted March 18, 2004 could be abs...or something bent? dont know much bout abs not having it myself....ask tim...hes theoretically got e30 abs Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted March 18, 2004 Have you checked your brake rotor for warpage? Cheers Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 19, 2004 HAHA what ever gus. check if you have a flat rotor like grant said. that my only idea. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted March 19, 2004 i think i have a similar problem grant and i only just machined my front discs Quote Share this post Link to post Share on other sites
