m_power
repowering e30
hi guys,
Sorry for all these anoying topics that i keep bring up...much thanks for you opinions,
I have a 316 and i was woundering how much trouble there is in putting a 2.5 L enigne and manual gearbox in? and would it be cheaper than buying a manual 325...i am asking this as my 316 is absoulty mint and it would be a shame to see it go...
thanks
Yeah, too much trouble, full loom, ecu etc, completely different setup.
I've put a 2.5 m50 out of a e4 525i in my 89 320i and it wasn't that much of a mission except for the exhaust manifold and wiring which I ended up doing did myself aswell. I've even used a manual steering rack out of a 316i e30.
The only problem is going from a 4 cylinder to a 6 cylinder motor as you have all the smaller gear on your 316i. If I were you I would look at a chain drivin cam 1800cc bmw motor for your car and a getrag 240 gearbox with nessecary conversion gear. Cause if you want to chuck in a 6 cylinder then you need more than just a motor and trans....
my 0.02c
Edited by OLLIE
It's an easy swap, but you MUST have a complete donor car to make it worthwhile. You will only be keeping the body and interior from your 316 as just about everything else is different.
