arktis 59 Report post Posted December 21, 2023 (edited) 40 minutes ago, Z3bra said: Hi, yep, there's Prestige Motorsport in Seaview, that's where I got mine done. Cheers mate, I'll give them a ring and see if the price is reasonable. Edited December 21, 2023 by E63 1 Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted June 26, 2024 Small update: Went back to the Dyno last week with a new tune. I am now using MHD+ Multi Map, as having just one full send map isn't that useful, especially this time of the year. Map 1: 16psi made 427whp and 577nm (This map is all I need on the street). Map 2: 21psi made 476whp and 663nm Map 3: 26psi Made 565whp and 863nm. You can however see quite a nasty dip up top especially on the high power map. (that map was actually 560whp and 808nm). This is likely a vanos tuning issue, my tuner has sent another revision, but also a result of timing corrections. I flash my old tune, which is the grey line on the dyno sheet, however the power still dropped off and has a dangerous amount of torque down low (Bendy Rod zone). The car pulled a bit of timing up top which robbed power, the ramp rate on the dyno was 2x more than doing a 4th gear street pull and the load was set to heavy on the Dynapack. The timing corrections are a lot better on the street. 4 Quote Share this post Link to post Share on other sites
darren_mk 69 Report post Posted June 27, 2024 Nice work, How easy is it to change maps? 1 Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted June 29, 2024 On 6/27/2024 at 5:24 PM, darren_mk said: Nice work, How easy is it to change maps? All I do is hold volume down and channel down buttons on steering wheel for a second and then select map with volume up and down, it's instant, rpm needle changes position so you know which map you selected. 1 Quote Share this post Link to post Share on other sites
