Cale 36 Report post Posted December 13, 2006 Hey everyone. This has been in this forum before but I cannot find it, so I'm sorry to bring this up again I have had my car serviced as you do and in the instrument display the service indicator light is in the yellow (sometimes red) and the "oilservice" and "inspection" lights are on. I understand that the proper reset tool on trademe is about $100 Does anyone have a link or any information on how to reset these lights? Many thanks in advance. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted December 13, 2006 What sort of car Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 13, 2006 Of course- 1989 E30 320i 4Door Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted December 13, 2006 Then this is what you need: http://www.bmwe30.net/cgi-bin/datacgi/data...&Section=02 Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 13, 2006 Cheers Andrew. I'm a bit anxious to try it as i do not have a "fused jumper wire". What do you think? Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted December 13, 2006 Cale said: Cheers Andrew. I'm a bit anxious to try it as i do not have a "fused jumper wire". What do you think? A bit of wire is fine - just make sure you don't put them in the wrong holes. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted December 14, 2006 Andrew said: A bit of wire is fine - just make sure you don't put them in the wrong holes.God knows how many times i've just used an old twistie tie to jumper mine. If you get the wrong holes it's not too bad, just make sure the car isn't in gear as you can trigger the starter motor if you get it wrong Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted December 14, 2006 Just did mine,was really bored whilst waiting for dye to dry on parcel tray so just did it. Easy as...hopefully itll stay on and I wont have to replace the batteries. Cheers Andrew for that. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 14, 2006 Same here Didn't even put it in the wrong holes Hope they stay on as well. Cheers guys. Quote Share this post Link to post Share on other sites
