Guest Andrew
Headlight maintainance rangi style
Guest Andrew
Well my headlights fill up with water, its bloody annoying - so periodically I have to empty them.
In case you were wondering how to remove the headlights from a pre-facelift euro spec e30 (the jappas have sealed beam lights). These are the non-sealed e30 lights.
Remove that bit of grill trim - 3 clips 2 screws.
Remove the chrome (or black in my case) trim around the headlight)
Heat up the plastic clips with the hair dryer - as they expand pull the light off the clip - do this with all three.
Empty out the water heh and proceed with the advanced drying technique :D
did you save my pet goldfish that i put in there? you flushed him didnt you!
Guest Andrew
amazing the bulbs could handle being under water - check out the corrosion - the main dipped beam light couldn't handle it.. as you can see its quite new.
noooooo.....nneeemmmmooooo.. damn i love that movie
sweet, now i dont have to worry about what to buy you for your next birthday!!
how bout you worry bout my one 2 years ago...im still waiting for my brazier filled with export!
Guest Andrew
Good effort, can you seal the headlight now (silicon??)
It actually appears to be leaking from behind -
true to form the headlight relay just managed to blow - so now headlights - but now I have that fixed but only 3 lights work. I wasn't really expecting the bulbs to work once I took em out and put them back in.
Just wondering, would the sealed units fit into your car ? there's a guy that advertises in the t&e every week, selling e30 parts and various other bits and pieces from bmw's, usualy seem pretty cheep to, he is in the bays aswell, it's a 478 number i think, he may have some? B.
failing that theres always the hella catalogue for brand new sealed beam for e30's, hit me up if interested
