phat328 0 Report post Posted January 15, 2007 does any1 no a gud place in hamz to take ur bmw to to get the roof lining re done?? and also how much?? And to get your springs compressed?? Quote Share this post Link to post Share on other sites
318isCoupe 0 Report post Posted January 15, 2007 does any1 no a gud place in hamz to take ur bmw to to get the roof lining re done?? and also how much?? Ahh, the BMW favourite! http://www.bimmersport.co.nz/forums/index.php?showtopic=3082 Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted January 15, 2007 If it's an E36, Drop it out yourself! I know a guy here in TGA that'll re-skin the fibreglass liner [& sunroof liner] for $200 Hey,I'm a Motor Trimmer & I won't bother doing it myself cause he's cheap! Smith Engineering in Maleme st TGA, will re-set your springs [while you are over here] pm me if you need to. Quote Share this post Link to post Share on other sites
phat328 0 Report post Posted January 15, 2007 If it's an E36, Drop it out yourself! I know a guy here in TGA that'll re-skin the fibreglass liner [& sunroof liner] for $200 Hey,I'm a Motor Trimmer & I won't bother doing it myself cause he's cheap! Smith Engineering in Maleme st TGA, will re-set your springs [while you are over here] pm me if you need to. yer its a e36.but not sure how to do it ma self aye..wont it done proply as iv heard storys tht sum guys compress them rough as..but need some1 in hamz to do my linning aye Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted January 15, 2007 yer its a e36.but not sure how to do it ma self aye..wont it done proply as iv heard storys tht sum guys compress them rough as..but need some1 in hamz to do my linning aye E36 headliners are easy to pull ,go to: http://www.pelicanparts.com/bmw/techarticl...2-headliner.htm This should show you how. Get hold of "Hove" on this forum or at carspot. He deals in Beemers, so he'll know somebody in Hammyton that could help Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted January 15, 2007 i can a good sedan hood linning from e36 , non sunroof $150 easy to fit in . in papakura 021433600ah Quote Share this post Link to post Share on other sites
phat328 0 Report post Posted January 16, 2007 i can a good sedan hood linning from e36 , non sunroof $150 easy to fit in . in papakura 021433600ah Thanks man..but mines a 2 door aye Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted January 16, 2007 If you don't mind the work, you can actually do it yourself - I ordered 3M Hi-Strength 90 glue in from a place in Auckland and re-did mine in black Microsuede which I got from Spotlight. In the end, though, you might pay slightly more than $200, but then again that was the price I paid for enough material and glue to do the A and C pillars too. It is a bit risky though, you may not be 100% satisfied with your work especially if it's your first time. So you might want to get someone to do it. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted January 16, 2007 did mine with a can of selleys KWIK Grip and black vynal from spotlight did all the pillars aswell cost me about 80 bucks all up for the material and glue, my second attempt (tried a different glue) turned out pretty good. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted January 17, 2007 How similar are e30 2 door and 4 door headliners? My friend has a black 2 door headliner that i can have, but i want to put it in a 4 door. Going on a visual inspection, i think i would only have to trim the new headliner to fit a 4 door. sorry for the jacked thread. Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted January 17, 2007 Tim, the bit that tucks into the pillars will be different, as the B piller is further back in the coupe than it is in the 4dr. just spray yours like gus did. Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted January 17, 2007 did mine with a can of selleys KWIK Grip and black vynal from spotlight did all the pillars aswell cost me about 80 bucks all up for the material and glue, my second attempt (tried a different glue) turned out pretty good. So what was the different glue? Glue is the biggest worry in this project... how long has yours held up? I'm on 1.5 years with the 3M stuff. Quote Share this post Link to post Share on other sites
MADBMA 0 Report post Posted January 19, 2007 So what was the different glue? Glue is the biggest worry in this project... how long has yours held up? I'm on 1.5 years with the 3M stuff. Ados spray adhesive, that lasted about a day then the sun came out and sent my hoodlinging sagging again i wasnt impressed, i should of read the can better it says thats its no good for aplications where in contact with heat, been about 6 months since i did it right with kwik grip, got a few bits that are starting to sag now but barely noticeble, i think i didnt use enough glue in thoes bits, i dont want to have to pull it out again as such a mission getting it in and out of the car. Quote Share this post Link to post Share on other sites
