325GRANT 0 Report post Posted February 12, 2007 hi all, does anyone know the best / most reliable way to eliminate vanos from an M52? cheers Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted February 12, 2007 Why, is yours rattling? Unplug the vanos solenoid first [that disconnects it] to remove it ,you will need a non-vanos intake cam & cam sprocket [longer duration] The short duration vanos-cam locked would be so gutless it wouldn't pull the skin off a rice-pudding! Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted February 12, 2007 when i put the M52 into my E30 (soon) i will be running it with my link and from what i understand the LEM V5 doesnt run vanos very well. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted February 12, 2007 If its e36 m52 it should be on/off vanos,easy to run. If its e46 m52 its variable. Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted February 12, 2007 Get a non-vanos intake cam & sprocket and front timing cover, and get rid of the vanos completely [someone will buy the vanos unit off you] There are plenty of cooked heads around with good cams in them Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted March 5, 2007 kerrynzl said: Get a non-vanos intake cam & sprocket and front timing cover, and get rid of the vanos completely [someone will buy the vanos unit off you] There are plenty of cooked heads around with good cams in them hey wat are the pros and cons of vanos? and does a m20 2.5ltr 89 325i have it? Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted March 5, 2007 BimmaPHNTCY said: hey wat are the pros and cons of vanos? and does a m20 2.5ltr 89 325i have it? No it does not. http://en.wikipedia.org/wiki/VANOS Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted March 5, 2007 BimmaPHNTCY said: hey wat are the pros and cons of vanos? and does a m20 2.5ltr 89 325i have it? NO, only M50's and newer. BMW created Vanos to get good top-end power without too much cam duration, and also get good bottom-end power at the same time with long duration cams a lot of cylinder pressure is lost during 'valve overlap' [a big cause of unburnt hydrocarbons/smog] plus the long duration cam wont idle as good or produce bottom-end power with vanos you can use a shorter duration cam for Idle/Smog/Bottom-end reasons and alter the lobe separation to recover at the top-end Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 6, 2007 Kerry heres a question for you. Aparently the vanos works in the off position at idle , the on position mid range and the off position top end. Make sense to you??? Quote Share this post Link to post Share on other sites
